Show Caps Lock status on HTML5 client logon
bblsystems
Post by bblsystems » Thu Jun 17, 2021 3:12 pm
We have users trigger the bruteforce lockout due to bad passwords, and often it's because the caps lock is on.
Maybe you could display a "CAPS Lock is ON" below the password field if caps lock is on.
The Windows logon page will display such a message to help users.
Here's how to display a caps lock status via javascript.
https://stackoverflow.com/a/348802/5216
I guess we could just add it to our logon pages ourselves using that technique, but others might benefit it the default config had that.
juwagn
Re: Show Caps Lock status on HTML5 client logon
Post by juwagn » Sat Jun 19, 2021 5:06 pm
it hasn't anything to do directly with html5 client logon but is the portal functionality common for native client and html5 client.
For our portal developers following could be useful.
Code: Select all
  (function() {
    var reg = 0, caps = false;
    var isCaps = function(a) {
      if(a) {
        alert("caps is pressed");
    document.addEventListener('keydown', function(evt) {
      if(reg == 0) {
        if(!evt.getModifierState) {
          reg = 1;
          document.addEventListener('keypress', function(e) {
            e = e || window.event;
            var s = String.fromCharCode(e.which || e.keyCode);
            if(s.toUpperCase() !== s.toLowerCase()) {
              isCaps(((s.toUpperCase() === s) && !e.shiftKey) || ((s.toLowerCase() === s) && e.shiftKey));
            } //undetectable char pressed
        } else { reg = 2; }
      if(reg == 2) { isCaps(evt.getModifierState('CapsLock')); }
Sincerely yours, JW.
