TSPlus Mobile App - Port Assignments
dcipher
Post by dcipher » Thu Sep 03, 2020 6:08 pm
I downloaded the Mobile App for Windows and added my servers. However, it works fine as long as the WebServer is listening on the ports 80/443 it does not work if you use custom ports. Can you add the ability to set the ports when you add a server. The ports should have default values but we should be able to change them if necessary.
Thanks,
Simon
Re: TSPlus Mobile App - Port Assignments
Post by admin » Wed Sep 16, 2020 10:33 am
I have forwarded your request to dev team.
