hello
we test your app at work
is it possible to have the html5 top menu always open and disable close to have this menu always visible locked on
thank you
html5 top menu
Re: html5 top menu
I am not sure of what you would like to achieve here. The top menu is already always visible, with the possibility of minimizing it with the upward arrows. The top menu can be configured to add extra applications and various other settings in the web tile of the admin tool, more information about this can be found here : http://www.terminalserviceplus.com/docs ... ile-device
