On every update:
- HTML5 looses it's background and is being reverted to default until you goto settings and just click save.
- there's an empty folder in %SYSTEMDRIVE%\tmp
Can you update the EXIT icon in the Floating Panel, since it says "exit" in English, which doesn't work for every other language?
And would it be possible to disable/remove the exit confirmation prompt?
Currently I'm replacing exit.ico and runlogoff.exe on every update to accommodate this.
Minor issues on update
Re: Minor issues on update
Oh no! Please leave that message!
Because at that moment, our customers can close their opened applications, before the session exits.
Without a confirmation, all their opened applications will be shut down and that can cause trouble.
Best regards
Jeffrey
Best regards
Jeffrey
We only run a single app, so for our case it would be nice with a disable function.
Ok, I understand.
But default behavior should be like it is now: show message with confirmation.
Indeed, some option to disable the confirmation message, would be a good solution for you/other.
Best regards
Jeffrey
Best regards
Jeffrey
