The ability to use a URL (i.e. mysite.com/software/html5.html?user=myuser&pwd=mypassword) to login into TSPlus is very useful. However since it uses a HTTP GET the login parameters are shown in the URL in the browser. To me it would be better if the URL did not contain the user's credentials for security purposes therefore I would like to suggest that an alternate HTTP post be allowed so the credentials would be part of the request body not the URL.
Thanks,
Simon
TSPlus web login using an HTTP POST
Re: TSPlus web login using an HTTP POST
Sorry, adding such a POST request is not in our roadmap and we do not plan to add it.
Consider trying our Web Credentials feature if you want to ease the logon process while staying secure.
Kind regards,
Adrien
Kind regards,
Adrien
Adrien
TSplus CTO
TSplus CTO
