Demo Expiry Limit
Demo Expiry Limit
When the demo expires it would be helpful if you could still connect for a limited time say 10 minutes before being disconnected. The reason I suggest this is because I recently had the following experience. I setup TSPlus on a server in a data centre 2000 miles away and my only access to the server is via Remote Desktop. The demo license expired before I could update it with the permanent license. So when I tried to connect to the server it logged me out after a fews seconds because the license had expired. So I was unable to uninstall TSPlus or update the license to a permanent one. So if I had a 5 or 10 minute window I would be able to either uninstall the software or install a license without being locked out of the server. As it was I had to call the data centre and they sent a technician to uninstall TSPLus.
Simon
Simon
Re: Demo Expiry Limit
This issue is well known and has been fixed recently, a pop up reminding the administrator that the trial is coming to an end should now be displayed properly.
Suggestion
If the demo license is expired, there should be a tool to apply the license like a small script that can be run to apply the license without going in the admin
I have the same problem. After the license expired I cannot access my machine with standard RDP, as the TsPlus signs me off from the machine automatically.
This is a sersious problem to our users and a serious threat to our projects since we cannot access this machine anymore.
We use the newest Tsplus version and the machine has windows 8.1 installed.
How can I access the machine again?
Uninstalling TSplus will restore the default behavior of your server, and you can also request a new trial license by opening a support ticket.
I cannot uninstall TSPlus if I do not have access to the server on the other side of the country. There needs to be a method to install a license from the command line or at least the when the license expires the program prompts you for a license file so you are not locked out. I just had this happen again because I uninstalled TSPlus so I could fix some issues and once I re-installed the software I was greeted with the "Trial Expired" message again.
Simon
Simon
I have solved this problem by remotely accessing the server drive and renaming the logonsession.exe. Then accessed the TaskMgr while the error dialog was displayed to run explorer.exe and uninstalled TSPlus.
Simon
Simon
Having thought about this a little more. I think a better solution than just saying your trial has expired would be to offer the following three options:
1) Buy a License
2) Activate an existing license (in case you are re-installing a previously licensed version)
3) Uninstall TSPlus
Using anyone of these options would ensure that you are never accidentally locked out of your server.
Thanks,
Simon White
1) Buy a License
3) Uninstall TSPlus
Thanks,
Simon White
As the 8.40 is coming out soon, the behavior of licensing will be different : When the trials comes out, one session will always be available with limited features (no printing or web access client), which will allow you to either uninstall TSplus or setup your permanent license. I know this on going issue as been a pain to deal with, but I can assure you that 8.40 will definitely solve this once and for all.
That sounds good.
Simon
Simon
