Major Release 11.70
Get the latest news, alerts & notices.
Locked
Major Release 11.70
Post by admin » Tue Dec 04, 2018 4:04 pm
A new version of TSplus is being uploaded right now and will be available within few minutes. This is version 11.70.12.2
- Working area when using the TSplus Taskbar: Even when setting "Full screen" in the Customize Taskbar, the application was not using the full screen area.
It is fixed now
- Overlap Taskbar: Even when setting "Overlap taskbar" in the Customize Taskbar, the application was not doing it.
It is fixed now
- Systray icon display: When one application was display the minimized button was overlapping the systray icon(s)
It is fixed now, and the sytray icon display is nicer.
- Explorer published as "one application": Explorer.exe process is not terminated when the user close it. As result, customers publishing explorer.exe
as one application had "zombi session" that could last forever and was never terminated.
It is fixed now
- Right click issue: When starting "one application" the right click was displaying 2 lines: Logoff and Theme switcher.
More: The Logoff was not working for rebranded versions of TSplus.
This two problems are fixed now
Re: Major Release 11.70
Post by admin » Mon Dec 10, 2018 9:17 am
A new version of TSplus is being uploaded right now and will be available within few minutes. This is version 11.70.12.7
- Compatibility fix for Windows 10 October Update (1809)
- New setting UseWinXshell=always in AppControl.ini to force WinXshell even on licenses with less than 10 users
- Added a title for Application Panel minimizing button
- Fixed logoff bug in edge cases when using alternate shell (taskbar, floatingpanel)
- Encryption Oracle Remediation policy is not reset at every boot anymore and it is only set by Setup and UpdateRelease if it was not already defined by the server administrator
The download links are unchanged:
Full setup program: https://dl-files.com/Setup-TSplus.exe
Update Release patch: http://dl-files.com/data/UpdateRelease.exe
Kind regards,
TSplus Dev Team
Post by admin » Fri Dec 14, 2018 4:25 pm
A new version of TSplus is now available. This is release
This is our comment for this new version: 11.70.12.11
- HTML5: when file filter applied and there was no one file to upload because of being filtered out the file frame was not automatically closed, fixed.
- HTML5: when file filter used the file filter was wrongly applied to folder names too instead resolving their content for subfiles, fixed.
- HTML5: when user logon contained space and parallelly existed similar sounding user with underline instead space and both logged in then their temporal folder was deleted if someone of both exited or reentered session. Now space in the middle is accounted as standalone char.
Post by admin » Fri Jan 11, 2019 5:20 pm
A new version of TSplus is being uploaded right now. This is version 12.70.1.11
- Load-Balancing: in case WMI is broken on an application server, LB will now approximate the server load instead of marking the server as "down". We still recommend admins to repair WMI, as WMI is a core Windows feature and is required by almost all applications
- Logoff: fixed Windows error message on Server 2003
- Added usewindowsshell=yes/no in AppControl.ini to force standard Windows shell in registry at reboot
- Floating Panel: fixed not customizable text in the "messages" box ("You are connected to:")
- HB and APSC executables are now code-signed to reduce false positive AV warnings
- Updated WinXShell
- Web Portal: improved groups membership retrieval method
Locked
