New Major release 11
- Happy New-Year to all: Major release 11.10 announcement
- The new Application Panel enables to display published applications like we do with the Web Application Portal but within one single session.
This program is handsome and can be customized by the administrator to deliver a nice user experience.
- The new Universal Printer Management tile enable to get in one single GUI the required tools to install, uninstall, display and handle the Universal Printer options.
The main goal of this new tool is to give to each administrator a better control what must be done when any issue with the Universal Printer must be fixed.
- The new HTML5 kernel enhancements are just great.
The behavior has been dramatically improved to deliver an excellent behavior on tablets or smartphone.
With these enhancements our goal is warrant the best possible solution to connect from a tablet.
- The Folder.exe program has been enhanced for a better user experience.
- The major release 11.10 is including the fix of all known issues except one.
On W10 with the latest MS KB, multiple sessions started with the same logon/password is not acting as expected.
(second sessions are capturing the first session). We do not know yet when
we will be able to fix this specific W10 issue.
Re: New Major release 11
A new version of TSplus is available.
- Corrective release:
On some systems the RDP client was handled as a RemoteApp client creating a logon issue it the full desktop was assigned.
It is fixed now
It is fixed now
A new version of TSplus is available. This is release 11.10.1.3
HTML5 enhancements
1. when using under iframe there were some rare cases where dead lock occured while trying to close session on main parent refresh.
That was because of unexpected event sequence when using with iframe.
That is fixed now.
2. when running under iframe and accident page refresh the program does extra work to restore the session instead to start new session.
Doing so, page refreshs under iframe are now safe.
3. when running under iframe we disallow accidental back button for modern browsers at least until page close or logoff.
HTML5 enhancements
That is fixed now.
A new version of TSplus is available. This is version 11.10.1.22
MyRemoteDesktop
Several light bugs were annoying and have been fixed.
If the user PC was too fast at reboot, an error was displayed. It is fixed now
Multiple instances of MyRemoteApp.exe was able to run. It is fixed now
Multiple instances of svcr.exe was able to run. It is fixed now
Warning: You need to generate a new connection client to benefit from these fixes.
UrlOnClient
When a customer wish to publish UrlOnClient to push a link on the user PC, AND, if this application
is declared as the single application started by the user (or is the Web Application Portal is enforced)
then, the UrlOnClient was not working as expected. It is fixed now
HTML5
iFrame handler has been enhanced
When the mini-mouse hits the right or the bottom screen bolder, we now enable an automatic scroll of the display.
It make easier for the user to click on buttons which are set on the right most side of the screen.
To enable this new feature you must change "moveScroll": 0 to "moveScroll": 2
MyRemoteDesktop
UrlOnClient
HTML5
A new version of TSplus available now. This is version 11.20.2.10
- The release 11.20 is our 2018 major release on which all our developements will
be based during the coming year.
The last fixes made are:
- The security feature "Allow CUT/PASTE" was not working as expected.
It is fixed now
- The custom target folder for the file transfer on a server was not working as epected.
It is fixed now
- The HTML5 new features for iFrames has been updated
On Smartphone/tablet we added the option to display a zoom-in/zoom-out buttons
on the top menu
- The Application Panel application was not display at the 4th position in the
application list. It is fixed now; doing so it less confusing for the administrator.
We added also the feature to automatically unselect the other reserved applications
when the Application Panel is selected
- New TSplus Remote Desktop app "ready". The server side is now ready to support
the upcoming TSplus Remote Desktop app for Android, IOS and Windows.
The marketing will start the communication about this exciting enahncement when the downloads
will be ready on Google Store and Apple Store.
It is fixed now
It is fixed now
on the top menu
A new version of TSplus is now available. This is release 11.20.2.18
- Corrective release 11.20
HTML5: the new version is providing a better handling of reconnections
Folder.exe: The design of Folder.exe has been enhanced
File Drag & Drop in HTML5: The target folder was not properly handled It is fixed now.
File Drag & Drop in HTML5: We added one new feature.
If you create a file named targetfolder.txt in the current user AppData directory In which you will write the destination folder for this user Then, instead of using the global value of destination folder, the drag & drop file(s) will be redirected to this user folder.
We modifyed Folder.exe to use this new feature. When the administrator specify by a command line that the folder to display is not the user Desktop, Then, this folder path is used as destination path for the drag & drop files.
Reconnecting a session: The code to handle the reconnection has been rewrite to avoid possible issue related to the change of the session ID
Remove folders/registry entries at logoff: The code to remove the session related folders have been rewrite to clean the disk and the registry at logoff. Please keep in mind that these action does not apply when the logoff is started by the Windows Start button or a GPO timeout, or a terminated disconnected session.
A new version of TSplus is now available. This is version 11.20.2.26
- Minor change in the file transfer (added to support of %userprofile%)
- Added "No mouse pointer" option in the AdminTool HTML5 client tab
- The Update Release program was set to be available to most customers, even the
ones who did not subscribed or renewed their Support/Update services.
It is no more like that, even for rebranded version of TSplus.
- The latest W2012 R2 KB was not compatible with TSplus.
It is fxed now.
It is fxed now.
A new version of TSplus is available. This is version 11.20.3.11
- HTML5 enhancements
1. improved mouse handling on PC browsers like FireFox, Chrome and IE Edge.
2. on IE Edge there is strange bug, when mouse cursors changed to fast then IE just has hidden cursor until next mouse movement. This update improves it.
3. in html5.html?xyz=** passed url parameters in non latin chars like chinese were incorrectly recognized by Chrome and FireFox, now fixed.
4. iOS Safari, when changing orientation before first finger touch the orientation was not changed, now fixed.
5. on mobile devices when used W.viewportminwidth/W.viewportminheight,
the file/print frames were incorrectly positioned. More over fixed W.scrollOverBounds = { "moveScroll" for handling such overflowing cases.
6. added new parameter W.target_filecopy_behavior = 1; Feature requested, as example by ** = 1 the file copied to target will overwrite old file without prompt instead enumerating copy numbers.
7. added support for port forwarding of OpenVPN messages, so this would allow usage of OpenVPN on same port. This option was asked by email.
8. a fix inside webime.au3
The download links are unchanged:
Full setup program: http://dl-files.com/data/ followed by your Setup program name
Update Release patch: http://dl-files.com/data/UpdateRelease.exe
Kind regards,
TSplus Dev Team
Kind regards,
TSplus Dev Team
This is our comment for this new version.
The release 11.30.3.24 is minor release.
- HTML5: Enhancements on the time zone management
- Client Generator: Enhancements and fixes when specifying a startup application
with commandlines. Now the administrator can specify
the full application path
the startup directory
and the application command line.
The local printers mapping is not more set as default.
- The AdminTool Gateway tab has been redesigned for a better understanding.
The Farm Manager tiles has been mode to the Gateway tab.
- When old systems was updated the license was sometime lost.
The Update Release program has been changed to avoid some of these license issues after Update.
- The Chinese character used in the HTML5 Client text message was corrupted after a restart of the
web server. It is fixed now.
- The security feature: Users MUST have an assigned application was not working
It is fixed now
It is fixed now
A new version of TSplus is now available. This is release 10.30.3.30
- From W10 Creator Update, it was not not possible to open multiple session with one user logon/password.
This is fixed now.
- We enhanded the Application Panel by adding a "Log out" text as
a second option to log out.
- The Client Generator Seamless client was always using the "green" color
even when the Blue or the Pink has been selected.
This is fixed now
- We added the option to select of not the "theming" option in the
HTML5 client tile of the AdminTool.
- The Update Release was inforcing "no theming" setting for HTML5.
Now we do not change the existing setting.
- The password entry field in the Web Credential was display in clear text
It is encrypted now
- The Printer Management tile was display in the AdminTool even for System
Edition. This is fixed now.
- French character was not correctly display in the AdminTool
It is fixed now
- In the Printer Manager tile, the READY status was display %READY
The % has been removed
- The French, Dutch, German, Chinese, Taiwanese, Russian
language fields have been updated
- HTML5 session started form the same tab was not supporting to force the use of HTTPS
It is fixed now
- User not entering a password in HTML5 received a message "wrong password".
This has been improved.
This is fixed now.
This is fixed now
It is encrypted now
It is fixed now
It is fixed now
