New Release 9.40
New Release 9.40
We are pleased to announce the general availability of the TSplus 9.40 release. This new release includes great new features and enhancements:
• Web Server improvements: The Web Server's default setting has been changed to provide a better secure HTTPS connection while increasing compatibility with more mobile devices. We also increased the maximum size for big files transfers. When the available memory's amount decreases to less than 50 MB, any new session is prohibited and the user is warned in order to warrant the Web Server stability.
• Web Portal Windows Client: The TSplus Reverse-Proxy and Gateway User/Server Assignments now support the Web Portal Windows Client (RemoteApp and RDP mode).
• HTML5 client: Folders can now be dropped onto Chrome to upload them to the server side. Web Credentials are now kept on page refresh as well as the supports of SSL multi-domain and large files transfers.
• RDP Defender: The administrator can white list an IP range instead of having to do it one by one.
• TSplus Taskbar enhancements: The system tray icons can now be displayed. Some applications are launched as an icon inside the system tray like the language selection icon. You also will be able to display your application in full screen mode when you maximize it, and it is now possible to set a left or a bottom margin. Using these new options can prevent the maximized application to overlap the TSplus Taskbar.
• Better performances: The overall CPU requirement has been lowered to warrant better performances when a large number of sessions are started.
• Universal Printer: Better detection of the landscape / portrait format, support of large documents and printing stability when some sessions are
disconnected or reconnected.
• Windows 10 Anniversary Update. This major W10 update will be available on August 2 and the 9.40 release is ready for this event.
All known 9.30 issues have been fixed and this release is including all of these fixes.
TSplus 9.40 is a major release and we recommend you to download and to apply the Update Release. For more information, go to our Website: http://terminalserviceplus.com
Re: New Release 9.40
A new version of TSplus is available.
- The code has been optimized to use less CPU. As result we expect to be able
to support more concurent users on the same server.
This enhancement will be extended during the next few weeks.
- HTML5: New way to handle Numlock/Capslock
Added language bar in the menu
Added fix for Japonese keys as well as Korean
Added the capability to acces the Hyper-V hypervisor console
Enhanced support of Corporate Firewalls/Proxy for the Gateway
A new version of TSplus is being uploaded right now and is available.
- Change of the Generated Client and on the RemoteApp client
For year we was using VeryPDF toolkit to enable the print on the default printer
or the enable for the user to select one of his local printer
However, VeryPDF is not a good product (complex to maintain, unpredictable
for some options, problem with landscape, with bar codes printing, with margins...)
As result, when we decided to change one parameter, the impact could be bad on others.
In this new release we do not use VeryPDF anymore.
We have replace it by Sumatra whihc is a light and very simple PDF printing tool.
- FloatingPanel: There was a bug when more than 7 applications was published.
This bug is fixed now.
HTML5
1. Added advnced way for CapsLock/NumLock/ScrollLock synchronization
between client and server instead simulating it via Caps/Num/ScrilLock key pressures.
2. W.disableTableConversion = false;
By true no unicode to scancode conversion used, but passed directly as unicode.
By setting to true this way will prefer chars passed from browser "as is" in users actual local typing language, however this way allows to type without changing rdp server language input.
Some ANSI only applications/inputs will stop to work like AWT Java. And Chinese/Korean/Japanese not possible too due IME conversion from latin chars, you would just get latin chars passed.
I do not recommand to set it to true if you want 100% compatiblity with all apllications running inside session, but if your used applications are unicode compatible, this may help you to avoid synchronizing languages.
3. W.preferscancode = false;
If you use primarily Windows with modern Chrome(or Chromium based like Opera etc.) or modern Windows FireFox that support scancode mode, you may set it to true.
HTML5
A new version of TSplus is now available.
- Performance enhancements
This release includes major enhancements of the Web printing performances and
the reduction of CPU usage when many users are connected.
It paves the way of the release 9.50 where, most probably, we will completely
remove the process webprint.exe "per user".
- HTML5:
The resize feature of the user web browser has been enhanced
The Universal Printer is now using the Virtual Chanel for a fast print job
The language selection menu has been enhanced
The upcoming Chrome mobile support has been added
- HTML5:
A new version of TSplus is now available : 9.40.7.21
- GPO tile of the AdminTool enhancements:
The settings made by the administrator was not saved when an Update Release was applied. Now, we do not reset default settings when the Update Release is applied.
The setting "Any second connection using the same logon will be terminated" was buggy. Now it works as expected. One detail about it: this feature is not supported on XP or 2003.
- Full desktop: the progress bar was displayed 15 seconds even if the Desktop
was already active for the user. That was not nice.
We have remove the progress bar display in such case.
A new version of TSplus is being uploaded right now and will be available within few minutes : 9.40.8.4
- Fixed freeze at logon in RemoteApp mode after upgrading an existing Windows to Windows 10
- Since several versions TSplus is of course compatible with Windows 10 Anniversary Update
- TSplus is now compatible with Java 9 (which is still in early beta and not recommended for production, but we are ready)
- Floating Panel finally uses our white flat look and feel
- HTML5 client: fixed edge case bug which could result in unresponsive script on browser's side
- HTML5 client: enhanced logon "token" feature with cross domain compatibility and utf8-base64 encoding
- HTML5 client: fixed AltGr keys in new version of Firefox (?, @, ...)
Version 9.40.8.13
- This is a minor release
- Enhancement of the code which is checking the compatibility to avoid warning pop-up when the setup is run on a server that has not right to have external HTTP accesses (in case of proxy, for example)
- HTML5
1. FireFox mobile introduced new bug with unreported scroll positions. We can again recommend FireFox mobile.
2. Added beta support for Palemoon mobile browse. Some peoples asked for that.
3. Added special admin printer mode handling for creating default printer settings that will be loaded as default settings.
This a new "undocumented" feature that will enable us, soon, to provide more printing settings.
- Minor fix: On slow system AND Web Application Panel,
all applications was started. It is fixed now.
Version 9.40.8.13
- HTML5
A new version of TSplus hasd been uploaded and is available.
- Speed up of the logoff process.
It will require one logoff/logon to be effective.
Then, after the first logon, the user logoff will be much faster
- HTML5
1. fixed cutomers issue with polyline orders 2. added new printer driver description file with ability to adjust scaling and margins (manual process so far) 2. disabled pause button which had same behavior as numlock.
3 Better print handling when using Universal Printer.
- HTML5
A new version of TSplus has been uploaded right now and is available. This version is :
- When starting one single application stored on a network drive, the time to
load the application can be quite long and as result, the user will get a logoff This is fixed now
- The File selection of the Web Download feature was based on a Windows API
using Explorer.exe. As result the user was free to browse any file on the server.
So, we are using our own File Select GUI now. As default, it only allow to
browse the user Desktop folder. This can be change by the Administrator
using the "Custom folder" option of the Web Preference tile
- HTML5
added special variables for improving click behavior
added some new rdp orders
- HTML5
A new version of TSplus has been uploaded and is available.
- Blinking issue:
This release avoid to create Blinking/Flickering issues.
For any user who will download the setup and install it on a fresh system, the issue will be avoided.
For any customer who currently have a blinking/flickering issue we are publishing a patch. In such case the proper process is:
- Download and apply this Update Release (mandatory)
- Download and apply http://dl-files.com/BlinkingPatch-2016.exe
Please note that for those customer, the blinking patch will be active, per user, after the first logon/logoff. This is just because the patch is changing HKCU registries
- Client Generator
For the printing, we was keeping all received PDF during a session. As result, if the user was printing a lot, the time to print any new document could be very long long.
This is fixed now
- HTML5
1. PCM sound format support for old PCs
2. Ctrl+Shift+Key fix
3. Native Samsung mobile browser fix for unsupported command.
- Blinking issue:
- Client Generator
This is fixed now
- HTML5
