New Release 9.30
Get the latest news, alerts & notices.
New Release 9.30
Post by admin » Tue Apr 26, 2016 9:35 am
- This is the release 9.30
- The Client Generator has been improved. It now enable to hide some of the redirected drive
The bug of the RDP mode which was always "full screen" is fixed
The Bit Map Cashing, which is a security issue, has been disabled
The option to optimize the bandwidth has been added
- The printing issue when the user disconnect/reconnect (in Web mode and with the Generate Client)
has been fixed.
- The existing "System Audit" tool was very basic. It has been improved with more diagnosis, more help and better suggestions.
The new tool is available in the "Server" part of TSplus AdminTool.
- The Load-Balancing feature has been improved and has now an optional "sticky sessions" setting.
When sticky sessions are enabled, any user who has an existing (connected or disconnected) session on a given application server will automatically be balanced to this application server.
This is very useful for example to get an existing session back after a network disconnection.
This new setting is available in the "Load-Balancing" tool, in the "Gateway" part of TSplus AdminTool.
- The RDP firewall "RDP Defender" has been integrated into TSplus.
If your Windows server is publicly available on Internet, then there is a 100% probability that hackers, network scanners and brute force robots are trying to guess your Administrator login and password - as we speak.
Using current logins and password dictionaries, they will automatically try to login to your server hundreds to thousands times every minute.
Not only this is bad for your server's security, but it can also consume a lot of its resources (CPU and bandwidth)!
Stop the constant attacks right now: install RDP Defender takes less than 30 seconds and will instantly protect your server by monitoring Windows failed login attempts and automatically blacklist the offending IP addresses after several failures.
You can of course configure it to match your needs.
This new tool is available in the "Security" part of TSplus AdminTool.
You can also install it on a non TSplus server for free from its website: http://rdpdefender.com
- The W10 support has been enhanced
- The HTML5 has been enhanced
Re: New Release 9.30
Post by admin » Wed Apr 27, 2016 3:54 pm
- Fix of performance issue in 9.30 when many users are connected AND only one application is published.
- The Client Generator does not display the Domain when the key word
nosavecredential is used in as user logon
- HTML5:
1. IE Explorer fix for non-latin char files. (Alan reported today, chinese chars)
2. Cookies secure tag and other security improvements. (issue ticket)
3. Upload folder auto creation if not available. (issue ticket)
4. Added new cursor to default editable (for displaying editable keyboard field)
Post by admin » Mon May 09, 2016 9:30 am
A new version of TSplus has been uploaded and is available.
- When printing 1) Using Web Portal, 2) Using RemoteApp client
There was a bug: multiple prints for the same document
This is fixed now
- When starting a session, some useless folders remains on the server side after logoff
This is fixed now
- When a large number of users was connected, the CPU dedicated to TSplus
processes became to high
This is fixed now
- HTML5:
1. Folder can be now dropped in Chrome, the folder structure stays same (folder dropping is Chromes non standard feature, the folder can only be dropped.)(The folder picking was not included, since does not contain folder path, but only file array from all sub folders) The folder is not yet auto copied to destinations like desktop etc, only separate files..
2. Bug fix with Numpad buttons, the state was not restored after page reload and the number 5 in numlock-off state was wrongly reported as numlock button, both fixed.
3. Restored some cookies for http connection, since their lack broke the connection restoring.
- Floating Panel was started twice
This is fixed now
- The background color was not properly apply
This is fixed now
- Multiple copies of svcr.exe was running on the user side
This is fixed now
- When resizing in HTML5, sometime, the published application was behind the background color.
It is fixed now
Post by admin » Tue May 17, 2016 8:01 am
- OpenOnClient: The open document was closed when the session did close and
the file transfer was not properly handled. It is fixed now.
- Client Generator: When the local disk are checked, all disk letter are checked
- The adding of 2 users on server OS due the Admin Cals was not properly handled
It is fixed now.
- In Select mode, when the Windows OS was not english, to printer pop-up was behind
the RDP windows. It is fixed now.
- In the Select print mode and in the Print on default printer mode, the portrait format was not
detected automatically. It is fixed now
- In the Select print mode and in the Print on default printer mode, if the document was larger than the
paper format the right side of the document was not printed. We decided to change the printer handler
(VeryPDF) to tell the print to be resized to the paper format.
Post by admin » Wed May 18, 2016 9:20 am
- OpenOnClient: when opening the Word or Excel document, an error was displayed
after few seconds by Word or Excel. It is fixed now.
HTML5 (important enhancements)
1. The printing has been improved to support large documents (hundreds of pages)
2. Internet Explorer Edge sends prior any GET request HEAD request (Chrome and FireFox do not do that)
This fix avoid memory leak or even Java machine crash.
3. About wrong credentials on CredSSP, the code have updated.
This will eliminate such issue, for example, if user activated NLA only clients.
4. When possible, the file to be downloaded will be sent via iframe instead window.open
This enhancement will avoid annoying messages about blocked popups.
Post by admin » Wed May 25, 2016 9:10 pm
- The Select mode on generated client was printing in Preview mode.
It is fixed now.
Post by admin » Mon Jun 06, 2016 1:19 pm
This is the latest news on TSplus release :
- Free Certificate Manager:
- you can now reset the domain name (e.g. if you want to change it)
- you can now type multiple domain names (e.g. "domain.com,www.domain.com,server1.domain.com")
- RDP Defender: you can now whitelist an IP range / network (e.g. 192.168.0.0/24 or 192.168.1.10-192.168.1.36)
- System Audit: fixed wrong description + fixed wrong license detection bug
- Added compatibility for latest Windows 10 Insider Build and Windows 7/2008R2 "Rollup" KB update
- HTML5 improvements and bug fixes:
- bug fixed when used with webcredentials on page refresh
- SSL multidomain support
- new variable W.UniversalPrinterServerDomain for a special edge case using IIS and multiple domains with printing in HTML5
- if used subfolder via -Dwwwroot, allow to handle cgi-bin folder of subfolder and root folder as cgi allowed
- workaround for reported issue with time zones that lead Outlook to show wrong time on emails
- XPS and PCL6 printers can now support auto print
- added some helper page for languages
- When disconnecting in HTML5, the user profile was corrupted.
It is fixed now (Adrien issue studied at Computex).
- When .jar files gets blocked for reading by external program, for example Antivirus,
the web servers did not starts as expected (Marc reported it to us).
It is fixed now
- Stable enhancement when the memory is not big enough.
Before starting new client instance, we check hothe memory requirement.
If less than 50 MB is availbale, we do not allow the new session and we display a warning pop-up.
Post by admin » Wed Jun 08, 2016 7:51 am
- This version fixes a bug with big files download in previous version, which was blocking RemoteApp Client update.
- You should update if you have any troubles connecting to your server when using RemoteApp Client.
