We are pleased to announce the general availability of the TSplus 8.20 release.
TSplus 8.20 major enhancements:
• The HTML5 client performances have been dramatically improved.
It even enables a nice display of videos, animated GIF, Flash videos!
This unique enhancement gives us a major advantage over any other RDP/HTML5 solution.
• The new HTML5 with “RDP native protocol” included delivers faster response time and better file transfer capabilities.
• The HTML5 Top Menu can be customized to add or to remove any Windows application.
This can be useful when only one application is published and you wish to add some more features to your users like changing the password or opening a documents shared folder.
• A new powerful “Reverse Proxy Server Role” is now available.
It enables to have one Gateway installed in DMZ with one single WAN IP address.
This server will act as proxy to connect to multiples Application Servers inside the Intranet.
With this new functionality, users will access the load-balanced farm of servers from the TSplus Web Portal front-end and this will be achieved using one single IP address.
• Windows 10 and IE 12 are now supported. TSplus is W10 ready.
• The management of the Support/Updates subscriptions and its renewal was not accurately done up to now.
To prevent such confusions, we decided to enhance this service.
It is now possible to buy on-line one, two or three years of Support/Updates services and to receive a “Support.lic” file which enables the activation of the TSplus license maintenance rights.
• The Universal Printer has been improved to avoid the system to wait for the user to complete each local print task prior to handle the next one.
This enhancement has also been implemented for the Open-On-Client feature.
The user is no more blocked when an Excel document or a PDF print is displayed on his local PC.
• All known issues of the 8.10 release have been fixed in the 8.20 release and many other minor enhancements have been added.
To download the new version, we recommend you to download and to apply the UpdateRelease.exe.
8.20 Release Note
8.20 Release Note
Re: 8.20 Release Note
A minor update of TSplus is available for download. Version 8.20.4.29
- HTML5 enhancement: Support of sound when using Internet Explorer
- When adding application, we avoid the case where 2 applications have the same
application name
- HTML5 Top menu; Fix of the case created when you disconnect and reconnect
- Systray icons: we avoid to display systray icon on most of the programs
application name
