We need to update our servers next week and have tested your current snapshot using the updaterelease.exe.
Can we download the whole setup exe so that we can be certain that we install this version next week? (If you release an update in the meantime this will not be the version we tested this week).
Thanks,
John
Full server download
Re: Full server download
Hi John,
When you run the Setup executable, just press Next and after that you can select the option to ONLY download the full installer executable.
Best regards
Jeffrey
Best regards
Jeffrey
You can download the update right here and check the box "Only download setup (do not install)" : https://secure-download-file.com/data/UpdateRelease.exe
Thanks, I don't think I got that option when updating directly from the TSPlus Manager.
John
John
