Use screensize in generated client
bzdega
Post by bzdega » Fri Dec 06, 2019 5:39 pm
How can i set display to the screen size in the .connect file?
In the possible parameters i only see full ore else, and some resolution.
I want to use the users screensize.
Is this possible?
Michael
Re: Use screensize in generated client
Post by admin » Thu Dec 12, 2019 6:10 pm
If you are using a full remote desktop, you could use the smart sizing :
