using TSplus farm with generated client
bzdega
Post by bzdega » Wed Oct 09, 2019 2:28 pm
is it possible to use a server farm with generated client?
My scenario:
2 TSplus server with different software, with the web login the user can choose which server he wants to connect (if he was assigned to the server).
But how can i use the generated client to connect to a specific server? Is this possible in general?
Michael
Re: using TSplus farm with generated client
Post by admin » Thu Oct 10, 2019 12:44 pm
You cannot use a connection client to choose your server as this feature is localized within the gateway portal. The solution here is to have two connection client, on for each of your two servers.
