limiting number of app's instances
damiri
Post by damiri » Sun Apr 07, 2019 1:33 pm
has anybody developed or figured out solution how to limit number of instances user can create with single application? Example: If MS Word is published, then only one instance can be running at any given time. Can't do two documents in same time, for example.
Br,
damiri
