Code: Select all
-preview off -default off -select on
These are the three settings that you can change to modify your generated connection client setting. Only one setting can be set to on, if a syntax error is present (as it is in your example), pdf preview is used.
If you wish to print automatically on default printer, choose -default on, if you wish to have a choice of local printer to choose from, choose -select on.
1- Universal Printer :
In order to print using the Universal Printer you need to use a generated connection client or the use of our web client and the edition Printer of TSplus or above.
The Universal Printer can be configured for three type of print job :
PDF preview on the local PDF reader : by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client, it will then be displayed in the local PDF reader of the client.
Select printer : by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client, a second print pop up will then appear with the choice of local printers.
Print on the default printer : This option is the best for those who do not wish to have a choice of where to print, by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client on the default printer.
You will find here will find more detailed information about this here :
https://www.terminalserviceplus.com/doc ... al-printer
We also have a tutorial video about this :
https://www.terminalserviceplus.com/video-tutorials.php
2- Printer redirection :
Using standard redirection can be tricky, because many prerequisites must be met in order for it to work. Printer redirection is not supported with the use of HTML5 and the TSplus Mobile App.
If you are using USB printers, make sure you updated the RDP protocol of your client computer to 6 or above to ensure maximum compatibility with redirected printers.
More information about printer redirection can be found here :
https://www.terminalserviceplus.com/doc ... er-mapping
