2FA authentification server URL?
bzdega
Post by bzdega » Mon Jan 28, 2019 12:56 pm
just updates to 12.20.1.27 and tried the new 2FA-feature - but what is the URL of the authentication server?
I tried my login-URL, but this does not work.
Michael
adrien
Re: 2FA authentification server URL?
Post by adrien » Thu Jan 31, 2019 10:13 am
If you only have 1 TSplus server then please check "Enable 2FA for the TSplus gateway and stand-alone application servers". This does not require an authentication server URL, because there is only 1 server.
If you have a farm of servers, then :
- enable 2FA on the gateway by checking "Enable 2FA for the TSplus gateway and stand-alone application servers"
- enable 2FA on every other application server by checking "Enable 2FA for TSplus application servers only": the authentication server URL is your gateway web portal URL.
Adrien
TSplus CTO
