When I first active the Ransomware Protection I get the message shown in the subject. Should I be concerned? When I later check the status is says Ransomware is running. I should add that I am running on Windows 2012 Server Standard.
Simon
Ransomware Protection Driver cannot be Loaded
Re: Ransomware Protection Driver cannot be Loaded
This message is discarded once you reboot your server.
