Client generator
Client generator
I'm testing the software for a client so I'm currently running through all the different settings to see what works best. Is it possible, having created a ClientConnector via the Portable Client Generator, to then edit it again to change a few settings, or do I have to simply create a brand new one?
Re: Client generator
Yes, it is possible to edit a generated connection client with this procedure : https://www.terminalserviceplus.com/doc ... ted-client
