hi,
Does TSPLUS support user profile disks? I know you can setup profile re-direction, but I want to setup user profile disks.
If it supports, how do I set it up?
Please advise.
Profile Disks
Re: Profile Disks
I have not much experience on this feature, however folder redirection is supported. As long as these GPO's do not rely on the RDS role than it should work.
