Problem with Folder.exe
rdomr
Post by rdomr » Sun May 20, 2018 8:31 pm
*Post edited with auto translation with Google, please post in English*
Hello.
I try TSplus 11.30.3.24. Windows 7 Pro. I use folder.exe to access the folder. I create a new folder inside this folder (right mouse button, context menu, create, folder). When you enter a new folder, the folder opens in explorer. How to make subfolders open in folder.exe?
Ps. In Windows XP it works fine, i.e. folders inside folders open in folder.exe
rdomr
Re: Problem with Folder.exe
Post by rdomr » Tue May 22, 2018 3:54 am
Hey.
I try TSplus 11.30.3.24. Windows 7 Pro. I'm using folder.exe to access the folder. I create a new folder inside this folder (right mouse button, context menu, creation, folder). When you enter a new folder, the folder is opened in Windows Explorer. How to open subdirectories in the folder .exe?
Ps. In Windows XP it works fine, i.e. folders inside folders open in the folder.exe
Post by admin » Tue May 22, 2018 11:36 am
For now this is not supported, I have forwarded your request to our dev team. For the time being, I would recommend to use the folder application to display the content of one folder only.
You could also publish the folder.exe application multiple times and add the content of a different folder each time.
