We would like the implement a new TSPlus environment. We would like to install the follwing architecture:
1x TSPlus Enterprise Server in DMZ as Gateway
1x TSPlus Enterprise Serber in LAN as Host
The reason for this is, the company will not allow any port redirectons direct into server LAN.
If I understood correctly then I only need to install the reverse proxy in dmz. All configurations and settings like webinterface customazing, SSL and so on needs to be done on the hostserver in the LAN. is this correct?
Sorry for newbi question I am quite new to TSPlus multiserver.
Thanks in advance
Juerg
Architecture with gateway in DMZ
Re: Architecture with gateway in DMZ
In this configuration you may not need the reverse proxy. All you need to do is set the correct settings on your gateway and assign users to your production server.
