HI
I have just installed version 10.50.10.26 and noticed that RDP defender is missing from Security tab?
I see RDP Knight which is not free. Why?
Is this a replacement for RDP defender?
I think you guys should have left RDP defender as free and then charge for RDP knight.
RDP Defender missing??
Re: RDP Defender missing??
Me too is missing the rdp-defender.
Is it a bug in the new version?
RDP defender is still present in C:\Program Files (x86)\TSplus\UserDesktop\files
Launch the "Setup-RDPdefender.exe" for this purpose. We are currently promoting our latest security add on : RDS-Knight.
RDS-Knight will provide more security features than RDP defender, check it out here for more information : https://www.terminalserviceplus.com/rds-knight.php
RDP Defender doesn't work. That makes me a little leery of RDS-Knight. Basically what you are saying is that TSPlus is wide open to hacks.... unless you want to spend yet more money. It should be part of TSPlus. Just sayin....
When we developed TSplus, our main focus was remote access. Security is a different topic on which we invested later on.
We stopped the support of RDP defender to focus on RDS knight, which has a wider range of configuration supported. You can check all of the recent update log here : https://dl-files.com/RDS-Knight-changelog.txt
RDS Knight is available for download in demo version so it is easy to try and setup to see if it matches your need.
