Hi all,
We are installing TS Plus on our environment and it is working properly but we want that when the user clicks on the application on HTML5 portal the application opens on another tab, a different tab from the same as the Applications are published.
Can someone help us with this?
Thank you.
Regards.
Open applications on differents tabs.
Re: Open applications on differents tabs.
This is possible if you use the application portal feature. Assign your applications to your users and check the application portal box in the web tile of the admin tool, more information about this feature can be found here : https://www.terminalserviceplus.com/doc ... ons-portal
