hi,
i try to install free certificate but i have 805 error, i don't understand what you mean by fqdn of current server, is it the tsplus server ?
Our domain name is online and point to IP of fixe Adsl
my network config :
Client use web access (work fine)
test.example.com (1&1 domaine)
Modem Adsl
Firewall
Tsplus server his name : Tserver
in Step 3 of Free and Easy-to-install SSL Certificate documentation :
i try many server web domain name : test.example.com
Tserver.example.com
example.com
Any help is welcome.
error 805 free certificate
Re: error 805 free certificate
What this mean is that you need to have a valid domain name that can be accessed from internet in order for this free SSL certificate to work properly.
Note also that dynamic dns provider such as Azure and DynDNS are not supported.
you can try it with another tool followed below "Update 01.08.2017"
http://support.tsplus.net/kb/faq.php?id=36
So probably you could identify your issue more detailed.
