hi i removed the tsplus from the server my question is
i will lose the license?
can i reinstall and another server?
remove and reinstall
Re: remove and reinstall
You will be able to use your license on a new server if you have a valid subscription to the support & update service. More information about this can be found here : http://www.terminalserviceplus.com/support.php
