New setup
frazergreen
New setup
Post by frazergreen » Thu May 25, 2017 11:01 am
Hi All
I've recently setup a TSplus setup using Gateway server model (also farm manager) with two applications servers. My questions are this:
1, When I publish applications from the farm manager do the settings get copied over to all the application servers? If so they are not. I've copied the Backupparam from the farm manager to each application server to make this work.
2, I've published apps with the floating application panel but the applications all open when you log in to the website.
hope this makes sense and any help would be gratefully received.
Frazer
Re: New setup
Post by admin » Wed May 31, 2017 8:19 am
Answers below :
1- You are correct, the farm manager does not replicate yet all application settings therefore copying the c:\backupparam folder after having saved your settings is still the best way to do this.
2- Make sure you assigned the floating panel to your users or group, otherwise all of your published applications will be launched at logon.
