We removed this feature from our roadmap due to its complexity.
MS Outlook Usage on Client Side within a Session
Re: MS Outlook Usage on Client Side within a Session
A total integration is not necessary (plugin etc) but only redirect Mapi protocol (when a software create a email) just like a "urlonclient"
Its very important with the actual office 365 (or 2016) installed on client side..
Impossible to release ?
Hi all,
I think "ds2kx" (how do you pronounce that,see above) is right. Our software generates a .EML file that can be send to the client, just like .DOCX or .XLXS.
When the .EML file is send to the client, i.e. Outlook is started and the email can be send via the local emailclient. What we need
is EMLtoClient or such.
It would be very nice if such a function can be added to TSPlus.
Best regards,
Aad
Best regards,
Aad
Put .eml in the list of extensions opened at the client side. Generate a eml. file on the server and use OpenOnClient.
