Export config to import on multiple servers
niles
Post by niles » Wed Feb 24, 2016 12:33 pm
I see there is a backup and restore options, but there seems to be unquie information pertaning to that server only. Is there a way to either export the config or copy a file/s to be used on multiple servers or is there a way to replicate across multiple servers within TSPlus? Setting up each servers to match identically is going to be a very long process in a large farm.
Please advise,
Niles
Re: Export config to import on multiple servers
Post by admin » Wed Feb 24, 2016 12:46 pm
You can copy the folder C:\Backupparam from a server to another and use the restore feature, this way all of your application publishing and assigning will be transferred. However be warned : you will need to reactivate your license on each server after doing so.
Our development team is working on this so that a loadbalanced farm of TSplus server does replicate their settings dynamically, this should be available this year.
MasterBlaster
Post by MasterBlaster » Tue Apr 11, 2017 10:54 am
admin wrote:Hello,
Was this replication ever implemented ? I am currently testing the latest demo version, and it would be great to know this has been sorted and how to do this.
Best Regards
Post by admin » Tue Apr 11, 2017 5:00 pm
Yes, it has been implemented and called the "Farm manager" feature, more information about this can be found here : http://www.terminalserviceplus.com/docs/farm-overview
