I use rdp connection with printer redirection...
Since i was on terminal server, the printer use the driver that i've install on the server (exemple : canon driver).
But now with tsplus, the EasyPrint (slow slow slow) driver is use...
How to do to use the driver installed on the server ?
Printer always use Remote Desktop Easy Print driver
Re: Printer always use Remote Desktop Easy Print driver
Using printer redirection can be tricky.
-First of all you need to make sure you use the same version of printer driver on client and server side.
-In some cases specific drivers optimized for RDP are necessary and available on the printer's website.
- Even after all this you may have trouble redirecting USB and exotic devices, this is why we have developed the Universal Printer. More information about it can be found here : tsplus.net/support/kb/faq.php?id=20
