I just upgraded to 7.8 from 7.2.
The installer said something about a warning had been detected, but it didnt bother to indicate what the warning is, or what should be done about it.
Anyone know what this is and/or what it is trying to communicate?
Mark
Install warning message
Re: Install warning message
You may need to uninstall TSplus and reinstall it. You can check what the issue is by opening an admin tool, go the licensing tile and click on "current system audit" to have more information about this issue.
