Hi all,
How does one get a raw .rdp file with the correct configuration in to connect to a published application in tsplus? I've setup a few apps but I can't see how to save just a plain old .rdp file...
Help much appreciated,
Cheers
Kev/.
How do I create a raw .rdp file for my Published Apps?
Re: How do I create a raw .rdp file for my Published Apps?
"Plain old RDP" file can be created and saved on each client computer. Go on a client computer, click start / execute / mstsc.exe. Then click "option" and "save as".
You could also generate a connection client which will allow you to use our file transfer utility and Universal Printer. More information about this can be found here : terminalserviceplus.com/docs/connection-client-generator
