Can apps be synced between servers?
We want to use our F5 to load balance traffic between tsplus servers. One issue we are concerned with is having to set the applications and user assignment on each server individually. Is there any way to clone or regularly sync this between all appservers?
Re: Can apps be synced between servers?
The list of published and assigned applications can be exported to another server by copying the following files on each servers of your farm.
loadbalancing.ini
appcontrol.ini
assignedapplications.ini
All of these files are located in the following path :
C:\Program Files (x86)\TSplus\UserDesktop\files
There will be no need to reboot, simply close and reopen the admin tool after this.
loadbalancing.ini
appcontrol.ini
