I have looked through the manual and forums, but I can't seem to see any options for an unattended install for TSPlus.
Are there command line switches for doing a quiet install of TS Plus.
From what I can see there are only a few options to get it installed so I would have though it would be possible.
Unattended install
Re: Unattended install
Yes you can use a command line to run silently a TSplus installation
Setup-TSplus.exe /silent
will do the job.
Warning: in such case do not forget to reboot when the process will stop running.
Kind regards
John Davies
will do the job.
Kind regards
John Davies
John,
Is it possible to make the /silent switch (actually silent).
I have done setup using /silent and /verysilent
/silent - there are some window popups and a prompt to reboot when finished
/verysilent - same window pop-ups and the system just reboots at the end
The problem is that when scripting the install (using cscript/PS/etc) when a gui interaction occurs the script will fail to complete.
Damian C. Stalls
Senior IT Engineer
Senior IT Engineer
I do the following using CloudFormation (aws unattended scripted installer) and it works.
Setup-TSplus.exe /VERYSILENT /NORESTART
Yeah if you run it from the command line it does flash up some windows at the end I think when it is installing the printer driver.
When they first switched over to this new installer it was causing problems for me, but after a few weeks (and versions) later it seems to have resolved itself.
I was talking with some of the developers of it and they were going to look into it, but I never heard back officially.
