Hi there,
I purchased 10 TSplus licenses for a client of mine July 2011, and since updating their SBS2011 server, they are having issues with some software which requires a constant SQL connection to the same server.
I notice that TSplus2012 has since been released. Can I update them using their existing license? Do you think this will help the problems?
Aaron
Licence and update question
Re: Licence and update question
Yes you can update the release without changing the license or the current parameters.
Just apply tsplus.net/UpdateRelease.exe and reboot.
Paul
Paul
hi again,
Thanks for the response, that's great.
Aaron
Aaron
