IPAD recommended client to use with TSPlus SOLVED
Share your TSPlus experience ad feedback on mobile platforms using our state of the art HTML5 RDP client!
atrialis
Post by atrialis » Wed Apr 12, 2017 5:59 pm
My customers are used to access my app trough MS Remote Desktop client for IPAD.
In the FAQ section you recommended the "Wyse PocketCloud RDP client for Iphone/IPad/Android", but it´s been discontinued.
so,
What would be the recommended IPAD client to use with TSPlus?
Best regards,
Alejandro Contreras
Re: IPAD recommended client to use with TSPlus
Post by admin » Sat Apr 15, 2017 12:27 pm
You will be able to connect remotely using the HTML5 web client : http://www.terminalserviceplus.com/docs ... ile-device
Or any RDP client available for tablets.
atrialis
Re: IPAD recommended client to use with TSPlus SOLVED
Post by atrialis » Sat Apr 15, 2017 7:05 pm
Thanks, that is what I needed to read!
Best regards,
Alejandro Contreras
