Is it possible to have a "RemoteApp" or "seamless" experience with HTML5?
Share your TSPlus experience ad feedback on mobile platforms using our state of the art HTML5 RDP client!
atrialis
Post by atrialis » Wed Mar 08, 2017 5:09 pm
I´m trying TSPlus and liking it a lot.
I wonder if is possible to provide the users a form of entering directly to the only app they would be using in TSPlus from their mobile device, ala RemoteApp publising.
I´ve tried the program parameters in URL and I couldn't make it work in the trial version. I maybe missing something, so, Can yo please direct me to the documentation to do it?
Best regards,
Alejandro Contreras
atrialis
Re: Is it possible to have a "RemoteApp" or "seamless" experience with HTML5?
Post by atrialis » Wed Mar 08, 2017 11:40 pm
Yes, I understand it will run in the browser, I'm talking mainly about launching the app.
Post by admin » Thu Mar 09, 2017 1:58 pm
The easiest way of achieving this is simply by publishing and assigning applications to your users and groups.
I recommend you to watch this video to get you started with TSplus : terminalserviceplus.com/videos/start-your-remote-desktop-solution.php
You will find here a documentation on how to publish new applications : terminalserviceplus.com/docs/application-publishing
And how to assign these applications to users : terminalserviceplus.com/docs/assigning-applications-to-users-or-groups
atrialis
Post by atrialis » Fri Mar 10, 2017 2:25 pm
Thanks for your answer, indeed it's part of what I was looking for.
I found easier and closer to what I want to use web credentials and url parameters to easy the launch of the app. (I have an additional login in the app)
- Client on W10pro64bits trough Ciscoconnect VPN
- Server W2012R2 using AD
I found inconsistent behavior between IE, Mozilla and Chrome, including occasions when sometimes what it´s presented is the whole desktop and not the app, with access to the desktop. I figure I must fine tune users privileges in the server.
I´m impressed with the performance and easy learning curve.
Thanks!
Alejandro Contreras
juwagn
Post by juwagn » Mon Mar 13, 2017 7:33 pm
the answer to question if browsers are able to display transparently background of desktop and all programs running behind browsers windows is - no. Browser vendors do not implement such feature due security reason that hackers could irritate users to do unwished actions.
So Seamless/RemoteApp is only possible with native clients...
