HTML5 FullScreen
Share your TSPlus experience ad feedback on mobile platforms using our state of the art HTML5 RDP client!
DamianS
Contact:
HTML5 FullScreen
Post by DamianS » Thu Dec 04, 2014 6:14 pm
How do I get the HTML5 client to run in full screen? The address bar from the browser is taking up valuable real estate..
Damian C. Stalls
Senior IT Engineer
Re: HTML5 FullScreen
Post by admin » Tue Dec 16, 2014 2:35 pm
You can change resolution for mobile devices, locate in html5.html the line :
meta name="viewport" content="width=1024, maximum-scale=1.4
and change it to a bigger value, like 1280 instead 1024, as example.
Remember, this will only affect mobile devices resolution.
INFORMATION NOT ACTUAL
BrunoB
Post by BrunoB » Thu May 04, 2017 5:01 am
I have tried the viewport customization you mentioned but I am not getting the desired result:
1. First I have used both width and height: <meta name="viewport" content="width=1280, height=1024, maximum-scale=1.4">
2. I dont see any difference when logging in from the iPad. I was expecting the real-estate my app has to open in to be larger (maybe I am missing something about the true viewport behavior)
3. After I log-off, the html5.html file is overwritten to the original content!
Can you help clarify what I am doing wrong?
Thanks,
Bruno.
juwagn
Post by juwagn » Thu May 04, 2017 7:17 am
the information is from 2014 and not anymore actual, therefore html5.html should never be tampered.
For reusing fullscreen on PC edit settings.js > W.full_screen = 2;
Fullscreen will not be supported on mobile devices due many breaking control limitations.
For changing viewport you should change settings.js > W.viewportwidth = "1024";
(height gets computed automatically by browser, viewport is mobile only setting)
additionally but not necessary you may set minimum width/height (mobile only)
W.viewportminheight = "200";
W.viewportminwidth = "200";
if resulting width/height will be higher than W.viewportwidth/coputed_height then the sceeen will overflow on relevant side.
